Solved
Where can I buy replacement side panels and acrylic sheets?
Last response: in Components
Best solution
there are companies that will cut the side panel professionally with a cnc and fit the acrylic window as well
doing it yourself is ok but without the right tools and the skill to use them the finish may not be that great
plus the cost of the spare side panel and the acylic may not be that much less than getting it done by a pro
heres one in the uk--dont know about other countries
the listing is for a different side panel but if you email them they can do whatever panel and whatever shape of window
you want
http://www.ebay.co.uk/itm/Coolermaster-Cosmos-2-II-wind...
you want
Thanks, I'll be much happier getting it done by a pro!
Ask the community
