Hello ,
I'm building a new PC and was debating on what type of CPU I should get.
I plan on gaming, do some overclocking (on air and nothing extreme). I plan to be using this after market heatsink for now:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106150
(I will for sure try water cooling in the future, probably not any time soon though)
And I also plan on doing some video editing in the future.
I was dead set on getting the i7 3770k (ivy bridge ), but I've heard overclocking and heat might be a problem and I've thought about getting a i7 2700k (sandy bridge) because of lower temperatures, but I'm not sure if it offers all that the 3770k has to offer when it comes to video editing. ( Ive also heard the 2700k wouldn't use my 3.0 PCIE Z77 Motherboard chipset to it's capacity. (I plan on getting a z77 sabertooth)
Now here I am asking for help. It'd be greatly appreciated if my question was answered thoroughly if not I still thank you for the reply. Any answers are welcome. If there's another CPU that you think would better fit my needs please do tell
BTW Here's all the other parts to this new PC I plan on creating:
CPU: Undecided 1155 socket preferably
Heatsink :http://www.newegg.com/Product/Product.aspx?Item=N82E16835106150
GPU: EVGA GeForce GTX 670 Superclocked
4GB VRAM 256 bit PCIE Express 3.0
MOBO: ASUS Z77 Sabertooth
RAM: G.SKILL Ripjaws Series 16GB (4 x 4GB)
240-Pin DDR3 1600
dual channel memory
HDD: 1 TB 7200 RPM Samsung F3
HDD Cache (Using SRT): Samsung 830 Series
64GB SSD
SSD Boot Drive: Kingston HyperX 3K 120 GB
PSU: Thermaltake Toughpower Grand 850W
240-Pin DDR3 1600
dual channel memory
64GB SSD
