Closed Solved
Help with new graphics card
After searching online and asking a few friends i bought
nvidia 520 2gb
i have installed it in my cabinet
i plugged in my VGA cable but i dnt get ny display
but when i plug my VGA cable in my motherboard i get the display
what might be the problem
My config is
AMD Phenom II X2 550 3.10Ghz
Gigabyte GA-MA74GMT-S2
2GB Transcend RAM
1.8 TB HDD
22" Samsung LCD Monitor
***NVIDIA 520 2GB***
3 answers Last reply Best Answer
More about help graphics card
  1. Best answer
    You have to disable you on borard graphics card in the bios. It is suppose to auto by pass the intergrated graphic. Or you can go into control panel click on system and security look for device manager.
    Click on that then look for display adapters dlb click on it look for the on board graphics and right click on it then look for disable and you are done. then shut down reinstall your card then reboot it should work.
  2. Best answer selected by 08shantanu.
  3. This topic has been closed by Mousemonkey
Graphics Cards Graphics
