Solved
Best sound card for the money...?
hey im looking to upgrade from my motherboard sabertooth 990FX onboard sound to a beastly sound card because im an audio junky and play games as well. i have 5.1 logitech speakers and asrtro's to be using it for so i wont need a 7.1 card. My price range is 100, i might go over if theirs one worth it. Any help appreciated :)
27 answers Last reply Best Answer
More about best sound card money
  1. $100 will be far fro the best, but ASUS Xonar DX 7.1 is good to have on your side.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006
  2. Read the review @ http://www.overclock3d.net/reviews/audio/asus_xonar_dx_7_1_pci-e_sound_card/3
    "Conclusion
    Impressive, a single word that sums up the Asus Xonar DX very nicely."
    "Conclusion
    Why are images so big?
  4. ASUS Xonar DX is the price/performance king right now. Above that level, you're basically aiming at audiophile grade playback and extra software features.
    What do u mean by so big?
    Do they look so big on this page, stretched left to right or the KB size?
    the only thing on the asus dx is i wish it had optical output if i were gonna plug in my astros...
    Resolution wise.
    Images are usually bigger than they need to be.
    http://www.amazon.com/ASUS-Channel-Sound-Card-XONAR_DG/dp/B0045JHJSS/ref=pd_cp_pc_0
    Another link - http://www.amazon.com/Xonar-DGX-PCI-E-GX2-5-Engine/dp/B007TMZ1BK/ref=pd_cp_e_1
  9. jay_nar2012 said:
    Resolution wise.
    Do u see that this way?
  10. goosemodz said:
    More of the same for more $$$.
    To really get advantage of better sound card,
    u need to have really good speakers or headset.
  11. Nope, like this
  12. Go to Manage my profile .
    And set this...
  13. Already set to yes.
  14. Well, I am on Chrome and it works fine for me.
    I don't know why its not the same for u...
    Try different browser to check, ...
  15. the images are fine for me, so go with the asus DX even without optical?
  16. Same on Chrome.
    It will supply great sound for the buck.
  18. Its almost 6 years old.
  19. so to finalize my decision you recommend the DX over any of the creative recon3d series cards? i was looking at the fatal1ty
    http://www.amazon.com/Creative-Blaster-Recon3D-Fatal1ty-SB1356/dp/B00654PTT2/ref=sr_1_15?s=electronics&ie=UTF8&qid=1344276255&sr=1-15&keywords=sound%20cards&tag=vglnk-c1001-20
  20. I still would take the ASUS. If I would want to get better, than it would be at around $200 range.
    But its your personal choice : )
  21. Best answer
    I am sure, they will satisfy your speakers and you : )
  22. Best answer selected by goosemodz.
    Are you talking about the optical out because you have an Astro Mixamp? Because the Astro A40s can plug directly in to the Asus Xonar DX, and still get surround sound emulation that IMO is better than Dolby Headphone since it also simulates environmental effects and the height of the sound source. With headphones, mind you.
    If you have the Mixamp, that can basically serve as an external DAC and soundcard if your motherboard's built in audio can supply 5.1 Surround through the Optical out port. The advantage of the Mixamp is that it can serve double duty between a gaming console and PC, but it doesn't offer as many features as an internal sound card.
    Anyway, hope you enjoy your results.
Sound Cards Sabertooth Motherboards Components Product
