Will my computer be compatible and what power supply shall I have
I'm new to build a computer and not sure if my components will be compatible or what power supply I should use.
AMD Bulldozer FX-4100 Socket AM3+ 4 Core Processor - 3.60GHz, 3.80GHz Turbo
http://www.amazon.co.uk/gp/product/B005UBNL0A/ref=ox_sc_act_title_1?ie=UTF8&m=A3P5ROKL5A1OLE
Sony AD-7261S-0B 24x Internal DVDRWRAM SATA Black Lightscribe
http://www.amazon.co.uk/gp/product/B003SM3HH0/ref=ox_sc_act_title_2?ie=UTF8&m=A3P5ROKL5A1OLE
Western Digital 2TB SATA 6Gbps Power Saving Internal Hard Drive OEM
http://www.amazon.co.uk/gp/product/B004VFJ9MK/ref=ox_sc_act_title_3?ie=UTF8&m=A3P5ROKL5A1OLE
Asus M5A78L-M/USB3 Motherboard (Socket AM3+, Up to 16GB DDR3, USB 3.0, uATX)
http://www.amazon.co.uk/gp/product/B0054U7HIO/ref=ox_sc_act_title_4?ie=UTF8&m=A3P5ROKL5A1OLE
Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit
http://www.amazon.co.uk/gp/product/B004CRSM4I/ref=ox_sc_act_title_5?ie=UTF8&m=A3P5ROKL5A1OLE
5 answers Last reply
More about will computer compatible power supply have
  1. What is your budget, your usage and time frame for buying? With your current components, assuming you dont have a video card you would need a 300-350 watt power supply. But that doesnt mean much without more info on your needs etc.
  2. My budget would be about £450
    My usage would be about 5hours every day
    I do not know what a time frame is
    I would just want it to play games like minecraft and world of warcraft
  3. Your choices seem compatible, but...
    Will you do a lot of multitasking, or run VMs? The 4 core AMD processor you have is better for such tasks, while a 2 core i3 2120 will be better for games. It will also consume less power.
    You can double check your power requirements using this link:
    http://www.extreme.outervision.com/psucalculatorlite.jsp
    But I feel that a 350 watt power supply should be more than enough. Make sure you get a 80plus certified one.
  4. Ok thanks for your help
  5. You should use benchmarks to check for power supply recommendations, not PSU Calcs.
New Build Power Supplies Computer Compatibility Systems
