I currently use a Antec 300, and basically my front 2 usb crapped out. The left one is jiggling all over the place, and the right one just doesnt take in any USBs at all, on top of that my front audio doesn't work. Opening the front panel literally takes decades, just to change position of 2 fans.
I live in Canada, but as stated in my previous posts i'll be in Oregon for a week, i'll be primary shopping at Frys. The ones i'm leaning towards are:
Corsair C70
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139014
Corsair 300R
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
Corsair 550D
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139012
Corsair 500r
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139000
Corsair 600T
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139005
NZXT Phantom
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146067
As you can see, i'm not that familiar with the cases, i only know mostly antec and corsair. I feel like i got cheaped out from the antec one, so i feel i wanna avoid them. I'm a big fan of just looks, so a side window panel would be cool. I read about the haf, but personally looks a bit too much for me. I'm really open to other brands as well.
The main goal im looking for is something sleek, a midtower with nice clean cable mangement + a window panel.
I definitely looked at the HAF, i simply didnt like the look =\
Corsair C70
Corsair 300R
Corsair 550D
Corsair 500r
Corsair 600T
NZXT Phantom
