Solved
NewEgg/TigerDirect Compatibilty Engine
Hello! A few weeks ago I was on NewEgg [] and there was the coolest thing to find parts compatibility. You enter your motherboard model and choose memory/videocard/etc and it give you a customized list of choices that work best with your mobo. Tonight I am looking for it and can not find it, so has anyone seen this or know where I can find it? I thought it was gold but never bookmarked it [[stupid me]]. Thank you!
3 answers Last reply Best Answer
More about newegg tigerdirect compatibilty engine
  1. Best answer
    http://lmgtfy.com/?q=newegg+compatibility+tool
    Don't use compatibility tools. If you have a PCIE slot a videocard is compatible. Go to the manufacturers website and check for compatible memory if you really must...
  2. Yes, I remembered the tool wrong
  3. Best answer selected by luckyniji13.
Graphics Cards Engine Graphics
