Any difference between these two fans?
10 answers Last reply
More about difference fans
  1. The part number is different, other than that I don't think there's a difference or at least not a significant one.
  2. They are the same fan i bought 3 of them from newegg.
  3. http://www.amazon.com/gp/product/B [...] d_i=507846
    maybe this from Cooler master :
  4. Both the same. 120MM LED Sickle flows fans. Comes in Red, Blue, and Green.
    Below are specs of the fan for your reference:
    http://www.coolermaster-usa.com/product.php?product_id=3010&product_name=SickleFlow%20120%20Red%20LED%20Fan%20(R4-L2R-20AR-R1)
  5. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103091
    I have three red led versions of this fan.One for rear exhaust and 2 on my hyper 212 evo setup as a push\pull.
  6. Which one is the newer one on Amazon?
  7. Hi if you are looking for fans try searching from the large catolgue distributors websites. Or try www.oemsecrets.com, i found 2 parts to repair my PC!
Cooler Master Components Product
