Need advice for cpu...stuck:((
Last response: in CPUs
Related ressources
jay_nar2012 said:
No video editing or stuff like that, then go with the i5.
+1 i5 should be your choice for sure. If you have an extra buck to spend maybe take a look at some of the gtx680 with different cooling (gigabyte, direct cu ii etc.) it could potentially increase the lifetime of your card since you will have less heat problems and in a few years once it will start performing slower in games you can more easily overclock it to keep it going :)
Ask the community
