PSU 6-pin cable help
Hi guys
I am currently looking for a 8-pin cpu power connector cable and it seems I cannot find anywhere to buy. If anyone can help me out I would trully appreciate it since I don't won't to waste any more money on new power supplies.
Thanks!
5 answers Last reply
More about cable help
  1. What PSU? Are you looking for an adapter cable? Extension cable? Topic says 6-pin...do you need a 6-pin or an 8-pin? What exactly are you trying to do?
    I am looking for an 8-pin (6-pin written by mistake). I have a 700W psu (cannot remeber the brand right now) and I am missing the 8-pin cpu power cable that connects the PSU to the mobo. I have heard that I will not be able to find one for purchase and that I have to buy a new PSU.
    Thanks for the reply!
  3. So you have a modular PSU and have lost the 8-pin PCie power connector? If that is the case, ten I'd contact the PSU mfr and ask them for a spare cable or buy one from them.
  4. Ok thanks I will contact the mfr then!
  5. Good luck...a new cable costs a lot less than a good quality PSU.
Power Supplies Cable Components
