Ok, so last night I finished building my first pc apart from I was waiting on my HDD being delivered, it all powered on and worked fine except obviously I could only get as far as "insert boot" cd etc, it made one short beep to say the power was on every time I powered it on as normal.
Today my HDD arrived and I've connected it up, mobo sata > hdd and psu sata > hdd but now when I power it on it beeps until I turn the machine off as if it is saying there is a problem. The only other change is I have removed my SYS_FAN because I installed this lastnight from an old machine but it spins at 3000rpm and is very loud hence why I don't want to use it.
Could this noise be because I have no SYS_FAN connected or is the HDD faulty or do I simply need to edit something in the BIOS?
Cheers guys
Cheers guys
