Need help picking out the best power supply.
  • Power Supplies
  • Motherboards
  • Components
  • Product
Last response: in Components
August 9, 2012 6:00:12 AM
Hey guys, I'm about to order PC parts this following Monday, and want to make sure I get everything right. I am quite unsure of the correct power supply I need, and help would be appreciated. I am also not too sure on the tower, either.
My current tentative specs:
  • CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
  • Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
  • Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
  • RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
  • Tower case: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
  • CD Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
  • HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
    What would be a good power supply? Are the tower and motherboard okay? It would make my life easier if you could find the correct product(s) in newegg.
    Thanks guys:)
  • More about : picking power supply
    August 9, 2012 7:37:44 AM
    Case recommendation:
    Power supply:
    A 600 Watt power supply will give you plenty of space for future updates.
    Another thing I would change personally - change the value DIMMs to something better looking. Take a look at these from corsair:
    They are 10$ more expensive, but are faster ,will look better on that motherboard And have better heat dissipation, which might come in handy when you're overclocking. Just a suggestion
    m
    l
    a c 111 ) Power supply
    a b V Motherboard
    August 9, 2012 7:38:47 AM
    OCZ...ew...
    m
    l
    August 9, 2012 7:52:05 AM
    What's wrong with OCZ power supplies?
    m
    l
    a c 158 ) Power supply
    August 9, 2012 12:20:55 PM
    The ModXstream are a middle of the road PSU...not partiularly bad performing but not great. The good thing is that they can usually be found at great prices. The Seasonic S12II-520 has two more years of warranty, is a very high quality PSU, only has 2A less power on the 12V, and costs less than the ModXstream: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
    The ZT/ZS series are better quality than the ModXstream but they also cost more and run into stiff competition from Seasonic, Corsair, Antec, XFX...
    m
    l
    a c 131 ) Power supply
    a c 150 V Motherboard
    August 9, 2012 12:49:46 PM
    +1 on the Seasonic PSU.
    Cases are an extreme personal preference item, but check out Rosewill's offerings. I've used probably 8 different Rosewill cases, some more than once, and been happy with all of them.
    m
    l
