Closed Solved
How to know will the GPu fit tight on system unit?
Nvidia GTS 450 has 21 cm length and 11.1 cm height. How to make sure will it fit on System unit?
5 answers Last reply Best Answer
More about tight system unit
  1. Measure the distance form HDD cage to the back of your case. If is bigger than 21cm is ok. And the distance from motherboard to the rear pannel , must be higger than 11.1 cm.
  2. Best answer
    Assuming a tower configuration with the CPU at the top and the card slots at the bottom:
    Inside your PC, measure along the slot the card will use from the rear bracket forward. If there's nothing in the area between that slot and the one below it along that line within 21cm, it will fit.
    Now measure from the face of that slot straight out to where the case cover will be when it is closed. If that distance is more than 11.1cm, you're good to go.
    If you find these instructions too confusing, cut out a piece of cardboard 21cm long and 11.1cm wide. Set it along the PCIe slot and against the rear slot bracket. If nothing touches it, the GTS450 will fit.
  3. Measure the length from the PCI-E bracket to the HDD cage, And measure the PCI-E slot to the side panel
  4. Best answer selected by dgbkiller.
  5. This topic has been closed by Mousemonkey
Graphics Cards GPUs Nvidia Graphics
