Solved
Will 900w Power SLI 680s
Last response: in Components
Hi, I am building a computer and I was wondering if the PSU I selected would power 2 GTX 680's SLI
Here is a list of all the parts I've selected for my build:
http://pcpartpicker.com/p/efDy
The PSU is the Antec HCG-900:
Here is the card I plan to use in SLI:
http://www.msi.com/product/vga/N680GTX-Twin-Frozr-4GD5-...
I don't plan on overclocking right away, but there is a possibility of minor overclocking in the future.
Will the PSU be sufficient for that build? If not, could you please recommend a PSU to me?
All help is greatly appreciated,
Thanks!
More about : 900w power sli 680s
Related ressources
Best solution
Power supply Master
Overclocking Authority
Hi there your PSU should be fine however i wouldn't risk it as that psu has failed some tests i recommend you get this instead it's better and has a seven year warranty http://www.newegg.com/Product/Product.aspx?Item=N82E168...
http://guru3d.com/article/geforce-gtx-680-sli-review/4
Here is Guru3D's power supply recommendation:
GeForce GTX 680 - On your average system the card requires you to have a 550 Watt power supply unit.
GeForce GTX 680 SLI - On your average system the cards require you to have a 750 Watt power supply unit as minimum. If you are going to overclock the GPU or processor, then we do recommend you purchase something with some more stamina.
Ask the community
