Solved
XFX power supply question
Hi,
After LONG research, I have decided to buy the XFX PRO 750W XXX version for my new gig.
My question what's the difference between
P1750XXXB9 vs P1750BNLG9?
http://www.ncix.com/products/?sku=73229&vpn=P1750XXXB9&manufacture=XFX
vs
http://www.ncix.com/products/?sku=62224&vpn=P1750BNLG9&manufacture=XFX#CustomerReviews
Here is what I know.
P1750BNLG9
* same as the P1-750B-CAG9(XFX XPS 750W Black addition)
* which got great review from jonnyguru
* http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=184
* which is basically the same as discontinued Seasonic M12D.
* 80 silver rated
P1750XXXB9
* looks very similar
* 80 bronze rated
From the XFX site I can't seem to distinguish between the two other than the bronze vs silver label. (price range looks similar also)
If anyone can share info on these two, it would be great!
Thank you in advance.
4 answers Last reply Best Answer
More about power supply question
  1. Best answer
    The P1750BNLG9 uses the older, more efficient Seasonic SS-750HT / M12D design.
    The P1750XXXB9 uses the Seasonic SS-750AM design, which is very similar to the designs used in the Corsair TX750 V2, NZXT Hale82, possibly a few others but can't remember them atm.
    I personally would choose the P1750BNLG9, because basically all units I have seen based on the SS***AM/AT design have the fan spin @ 1000RPM in idle, whereas with the SS-***HT design the idle fan speed is 600RPM. It is possible that XFX have lowered the idle fan speed of the P1750XXXB9, but I personally wouldn't take the chance.
    I personally would choose the P1750BNLG9, because the fan spins slower in idle (600RPM vs 1000RPM) meaning that it is quieter most of the time.
    Hmm so that's another + for P1750BNLG9 in addition to being silver.
    Is there any disadvantage of P1750BNLG9 since it is older design?
    You'll get the proper answer to that question on JG forums.
  4. Best answer selected by lastsd.
Power Supplies Silver Components
