Closed Solved
Building first gaming computer, are all my parts compatible?
Here are all the parts I'm considering buying:
EVGA Geforce gtx 570 (fermi) classified
Western Digital Caviar Black 1 TB 7200 RPM
Intel Core i7-2600k Sandy Bridge 3.4GHz
(2) Patriot Signature 8gb 240-Pin DDR3
Boxed Intel Desktop Board Extreme Series ATX Form Factor for Second Generation
Corsair Enthusiast Series TX750 V2 750W
If someone could just let me know if this all looks good, that would be great.
14 answers Last reply Best Answer
More about building gaming computer parts compatible
  1. What is this for? If gaming, bump the 2600k to a 2500k, and the 570 to a 7950 or 7970!
  2. Whats the advantages to the 2500k?
  3. Where is the motherboard?
    Depends what you want the computer for, for gaming he's recommending the 2500k with a better GPU to maintain price, the 2600k in these circumstances won't perform any better than the 2500k.
    It is dependant on usage.
  5. the motherboard is a Boxed Intel Desktop Board Extreme Series ATX Form Factor for Second Generation Intel Core Family Processors BOXDP67BGB3
  6. I plan to use it for gaming, however, I did some research and decided on the i7 2600k because I want to be able to upgrade my computer in the future when games take advantage of the multiple threaded architecture. Im pretty new to building computers so thats just some of my thoughts, I could be wrong.
  7. By that time, you would probably want to upgrade anyways.
  8. ok, so I have changed my cpu to a i5 2500k and my graphics card to a evga geforce gtx 680. Still no one has answered my question though, will all my parts be compatible together?
  9. Can you link the motherboard? You could probably get a 650W PSU. Also, get 2x4gb sticks of RAM. Such as this one.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
    This is the motherboard I'm looking at:
    http://www.amazon.com/gp/product/B004PQBT8C/ref=s9_simh_gw_p147_d0_g147_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-3&pf_rd_r=1PQT74EQXGZKV13NW58N&pf_rd_t=101&pf_rd_p=470938811&pf_rd_i=507846
  11. Best answer
    Would you consider this motherboard? P67 is outdated.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
    Also, to answer your earlier question, yes, everything is compatible.
  12. Best answer selected by cheynemurray.
    Thanks for all the help. I'm pretty new to building PC's so your advice has been very helpful.
  14. This topic has been closed by Proximon
Homebuilt Systems Product
