I honestly can't take it anymore. My graphics card is making a loud humming, screeching noise, whatever you want to call it.
I can safely say it is the gpu since I took the whole thing out and ran the computer and the noise was gone. I have also done some research and read up on coil whine. I have stuck my ear up to a straw to all the caps and they are not causing the problem (at least I think). I have manually stopped the fan with my hands, noise still occurs. I have ran the computer with the fan and heatsink of the gpu disconnected (only for few seconds), noise still occurs. This also is not some random thing. The noise does not only occur during games, but rather from startup, to idling on the desktop, to shutdown. I have reconnected all my power supply cables to the motherboard, reseated my graphics card multiple times, noise still occurs.
It is not hindering performance from what I can tell, which is a relief. Games still run at normal fps counts and the gpu temps stay reasonable.
Here are my specs...
Mobo-Asus P7H55-M Pro
CPU-i5 760
GPU-Geforce 9800gt
PSU-GS Series BFG Tech 450 watt ATX 12V 2.2
I would like to fix this problem without buying a new card. Please someone help me from going insane.
CPU-i5 760
GPU-Geforce 9800gt
