Solved
[NEW BUILD] $1300~ PC Need advice!
I live in Canada and my preferred sites are www.directcanada.com and www.canadacomputers.com
Budget: $1250 before taxes
What I currently have:
Motherboard: Asus P8Z68-V/GEN 3 Z68
http://www.directcanada.com/products/?sku=16950BD6381&vpn=P8Z68-V/GEN3&manufacture=Others
(190)
Processor: Intel Sandy Bridge I5 2500K
http://canadacomputers.com/product_info.php?cPath=4_65&item_id=035530
(230)
Video Card: Asus Radeon 7850
http://www.directcanada.com/products/?sku=10530BD5564&vpn=HD7850-DC2-2GD5&manufacture=ASUS
(250)
RAM: 8gb Corsair Low Profile
http://canadacomputers.com/product_info.php?cPath=24_311_312_612&item_id=039987
(50)
SSD: Crucial M4 128gb
http://canadacomputers.com/product_info.php?cPath=179_1088&item_id=039183
(140)
Hard drive: Suggestions please! Not looking for high capacity since I have an 3TB external hard drive.
(~100)
Power Supply: Suggestions please!
Case: Suggestions please! I prefer a case that provides low-noise and high-performance. I do not want to spend more than $100-125 for it.
Total: 960 before taxes here (included the hard drive assuming it's 100)
Thanks!
12 answers Last reply Best Answer
More about build 1300 advice
  1. Samsung F3 500 gig hard drive , WD black would be my choices
    The sonata 3 is an excellent case . Very quiet and well made , but the cooling is not spectacular since its designed more for office use rather than gaming
    For a gamer case its hard to beat the Antec 300 two
    http://www.directcanada.com/products/?sku=10370AC7501&vpn=THREE%20HUNDRED%20TWO&manufacture=ANTEC
    For a quiet performance case consider the Antec P280
    Use this
    http://www.realhardtechx.com/index_archivos/Page362.htm
    to choose a power supply .
    500 watt 80+ bronze [ or better] rated unit will do fine
  2. Best answer
    That case and psu combo will work fine for a single 7950. If you plan on going with a single card set up then look at this board down below.
    http://www.directcanada.com/products/?sku=16950BD1852&vpn=Z77%20Pro%203&manufacture=Others $127.44
    ASRock Z77 Pro 3 ATX LGA1155 DDR3 CrossFireX 2PCI-E16 1PCI-E1 2PCI SATA3 HDMI USB3.0 Motherboard
    http://www.asrock.com/mb/overview.asp?Model=Z77%20Pro3 <----- another look at that board
    If you want the option to add another 7950 later on for a dual card set up, then look at this board and psu down below.
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131837 $154.99 FREE SHIPPING
    ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
    http://www.directcanada.com/products/?sku=15180AC8566&vpn=P1650SNLB9&manufacture=XFX $78.50
    XFX 650W PRO650W Core Edition Single Rail ATX 12V 53A 24PIN ATX Power Supply 80PLUS Bronze PSU
    Nice find! I was actually starting to look into z77 since Ivy Bridge comes out this weekend. Processor may change to 3570k to match. The PSU is nice, but I think I can probably survive off a 550W or 600W. I'm trying to get all the parts together and get the PSU and case last.
  4. NEVER skimp on the PSU. Getting it last is not wise.
    A 500w psu will easily push a single 7850. For dual 7850's you want a 650w psu. I linked two of those boards. The Asus is set to run dual cards and that Asrock board I linked is for single card set up.
  6. I'll probably pick up the Asus one for two reasons:
    1. I like ASUS
    2. I will probably upgrade my computer which this motherboard allows for.
    I suppose the 650w is a good choice for me then. I just hear a lot of people going by with a similar build with 500-600w.
    The psu might , but those components in that case will run hot .
    There is only a single 120 mm fan fitted , and a long graphics card prevents you adding a "front" fan because it has to be mounted on the back of the hard drive cage
    But if he owns a dremel he can hack a hole in the base of the case and improve cooling that way
    Good catch. I didn't even give that case a one over like I should have. I used a dremel back in the day on a few el cheapo CM cases. It didn't look pretty but it worked. lol
  9. Removed that case and psu combo from the build. I just liked the way the case looked to be quite honest.
    The sonata is a really nice office case . I have build pc's in a couple of them
    Im like you and want as quiet a case as possible . The Antec P280 was my choice for my pc . More expensive , but capable of keeping a powerful pc cool and quiet .
    http://www.directcanada.com/products/?sku=11180AC3384&vpn=CC-9011014-WW&manufacture=CORSAIR $73.50
    Corsair Carbide Series 300R Black Gaming Case ATX 3X5.25 4X3.5 Front USB Audio No PSU
    http://www.corsair.com/pc-cases/carbide-series-pc-case/carbide-series-300r-compact-pc-gaming-case.html <---- another look at that case
    or....
    http://www.directcanada.com/products/?sku=11180AC6193&vpn=CC-9011011-WW&manufacture=CORSAIR $86.52
    Corsair Carbide Series 400R Mid-Tower Case ATX 4X5.25 6X3.5INT USB 1394 No PS
    http://www.corsair.com/pc-cases/carbide-series-pc-case/carbide-series-400r-mid-tower-case.html <---- another look at that case
  12. Best answer selected by macadoly.
New Build Systems
