I have two 7970s in crossfire and an Intel i7 3770 3.4GHz. I had some problems a little while ago with fps dips into forties so I tried many different things including completely reistalling windows but I ended up overclocking it to 3.5GHz the same speed as a 3770K. (at turbo it gets 4.3GHz instead of stock 3.9).
Now in bf3 I still am getting dips into fifties when the whole map is in view. I am finding it very hard to believe that this would be a graphics problem unless indeed two 7970s cannot even provide constant 60 fps on ultra (which would be ridiculous). for example i play tdm on noshahr canals and it runs about 100-140 fps unless i am on the side dock area then its 80-95 and when i die and it goes to the loadout menu overlooking the whole map, the fps drops into 50s.
-If i play on an empty server, no dips. Another reason I am thinking it is not a problem with the GPUs.
-At these different points overlooking maps the fps does not change at all if both gpus are oc it stays the same fps as it does on stock clocks.
-While I sit at the top of the tower on Gulf of Oman looking down with fps reading 55, both GPU usage are at 69%.... so if shouldnt they be pumping out more power to get it to 60...
Thankyou for any help
