moddedmatt :
in those choices, i would go with the HAF 922 since it has good airflow for a good price.
though, may i suggest this case? this is the one i got and I am really pleased! http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
Thanks for the reply,
I am from India so newegg is not available and Rosewill too
in my views :HAF X-little more expensive but interior black coated and have window
:HAF 932-Expense can handle but side window with not properly placed and interior not painted
:HAF 922-like this,good in budget,butcomparing to 932-it is too small,and no side window at all
:NZXT Guardian-got side window,interior coated,temp.monitor but doubt its airflow but cheap price at local store
ihave core i7 2600k and p8z68 v pro gen/3
currently running gtx 285 and will upgrade to gtx 680 this christmas(or gtx 685 if it is true and available)
Budget 14000INR
Store:Ebay.in/Flipkart.com
