sumirandhamaskar Honorable Mar 5, 2012 142 1 10,680 Aug 11, 2012 #1 I recently bought a new gtx 560 and a Crosair VS450 PSU which has only 1 ''6 pin'' Power Connector & gtx 560 needs 2. So to Use the 4 pin to 6 pin Power Adapter, Should i Use both 4 pin Male Connector Into the Female 4 pin PSU Or Only 1 ???
vasilisvvv Honorable Apr 16, 2012 112 0 10,690 Aug 11, 2012 #2 you must use both of them, i had the samew issue older with a 560 ti.. Upvote 0 Downvote
mocchan Splendid Dec 28, 2011 3,580 0 23,460 Aug 11, 2012 #3 What do you mean both? Did your GPU come with a Molex-PCI-E 6 pin adapter? If the adapter has two Molex connectors, then yes, you should use both. Upvote 0 Downvote
