I'm gonna build a PC with these specs:
Case - Cooler Master Haf 912 Plus
PSU - Corsair TX650W V2
Motherboard - Asrock Z77 Pro4
CPU - Intel Core I5 2400
Cooler Cooler Master Hyper 212 Evo
Crucial Ballistix Sport DDR3 2x4GB
HDD - WD HDD 500GB 7200RPM SATA 16MB 3.5 CAV BLUE
GPU - SAPPHIRE TECHNOLOGY Radeon HD 7850 OC
DVD Burner - LG 22x DVD-RW Black
ASUS VS229H Monitor LED 21,5" Full HD - Resolution (1920:1080)
My question is: Will I be able to play the latest games with Maxed Out Settings in that resolution with these specs? Or should I buy a monitor with less resolution?
PS: It's worthless you say I have to change to a more expensive GPU because I won't alter it. Money is the reason
