Hello,
Hi, Im in the middle of buying a new computer and i was wondering if this setup would be able to max out flight simulator with good fps. Im also using this computer for surfing the internet , and homework. My budget is 1000$ - 1250$ and im 100 dollars overprice with what i think is a perfect setup. Im using the site ncix.ca, so if anyone thinks i should change some for the same price/ less and get same performance , or not better please let me know .
My specs are :
Intel Core i7 2600K Quad Core Unlocked Hyperthreading Processor LGA1155 3.4GHZ Sandy Bridge 8MB ( not overclocking, cant risk computer dieing early)
Seagate Barracuda 1TB 7200RPM 64MB SATA 6Gbps 3.5IN Internal Hard Drive - hard drive
Diamond Xtreme Sound 5.1 Channel PCI Sound Card - sound card
Heatsink Included With My CPU -- heatsink
ASUS P8Z77-M mATX LGA1155 Z77 DDR3 2PCI-E16 1PCI-E1 1PCI SATA3 HDMI DVI USB3.0 Motherboard -- motherboard
Corsair CMZ8GX3M2A1600C9 Vengeance 8GB 2X4GB DDR3 -- ram
EVGA GeForce GTX 570 HD SC Fermi 797MHZ 1280MB GDDR5 2XDVI Mini-HDMI DisplayPort PCI-E Video Card - video card ( graphics)
Thermaltake TR2 600W ATX12V V2.2 24PIN Power Supply with 120MM Fan
Thanks in Advance for your response, i will give helper top comment please help me out. ( also can someone give me some insight on turbo boost?, what is it , is it like ocing? Also will it give me alot of heat on a normal stock cooler?)
My specs are :
