Hello, my question is if these are good specs to max out fsx.
Intel Core i7 2600K Quad Core Unlocked Hyperthreading Processor LGA1155 3.4GHZ Sandy Bridge 8MB - processor
Seagate Barracuda 1TB 7200RPM 64MB SATA 6Gbps 3.5IN Internal Hard Drive -Hardrive
Heatsink Included With My CPU -- Heatsink
ASUS P8Z77-M mATX LGA1155 Z77 DDR3 2PCI-E16 1PCI-E1 1PCI SATA3 HDMI DVI USB3.0 -Motherboard
Corsair CMZ8GX3M2A1600C9 Vengeance 8GB 2X4GB DDR3-1600 CL9-9-9-24 Dual Channel Memory Kit -- ram
EVGA GeForce GTX 570 HD SC Fermi 797MHZ 1280MB GDDR5 -- video card
Thermaltake TR2 600W ATX12V V2.2 24PIN Power Supply with 120MM Fan -- power
My budget is $1000- 1250 the needs are gaming ( flight sim x ) , and normal surfing internet, and doing homework etc.. ( mostly gaming needed though to max out flight simulator) Im using the site ncix.ca to make my build soo if there are any parts that i should use other then the ones im using please let me know. I want full fsx performance. I think i have it right on though.
