Approximate Purchase Date: Within the next 2 months (Sorry I can't be more specific, it depends on money basically)
Budget Range: 600-800 (Closer to 600 if possible)
System Usage from Most to Least Important: Gaming, Graphic Design (without 3D rendering), Streaming Videos. Small amount of 3D rendering (3dsmax), music production (Ableton), and Video Editing (Premiere and After Effects)
Parts Not Required: Keyboard, Mouse, Monitor, Speakers, OS (Windows 7 Ultimate 64bit), Power Supply (Corsair TX 750W), Optical Drives, Hard Drive (OCZ Vertex 3 120GB).
Preferred Website(s) for Parts: newegg.ca canadacomputers.com ncix.com
Country: Toronto, Canada
Parts Preferences: Best Product/Match Available (Haven't had any brand loyalty or preference in about 8 years)
Overclocking: At some point, but not needed immediately
SLI or Crossfire: At some point, but not needed immediately
Monitor Resolution: Right now I use 1280x1024
Additional Comments: I'm very out of the loop for hardware at the moment so I'm having a rough time figuring out the right combinations based on price vs need. I'd prefer a quiet computer, but it's not a deal breaker for me.
Honestly right now the only thing I've really had an eye on is the i5 2500k, but any option is open right now. Just looking for a solid gaming build that doesn't cost me an arm and a leg and will be somewhat future proof if possible. So basically, what combination of CPU, GPU, MOBO, and RAM will give me the best bang for your buck with a Corsair TX-750W, and OCZ Vertex 3 120GB SSD. Also, I most likely need a new case for this setup, the cheaper the better.
Hopefully that fulfills what is required to pose the discussion thread here. Let me know if any other information is needed.
Thanks.
Thanks.
