i am getting a sapphire amd radeon hd 7970 and want to hook it up with 3 of these monitors
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009266
but dont know how to set it up with eyefinity but it only has 1 DVI plug in heres a link to the 7970 so u can look in the picture and see everything that comes in the box
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102961
as you can see it does come with a mini display port to dvi adapter but i need step by step instructions on how to set it up
