Hello all. I am sorry to start another Eyefinity setup issue thread but I just cannot find an answer with my current hardware setup. I'll describe exactly what hardware I'm using and what I've tried below and if you see anything wrong please let me know!
Video Card:
XFX Radeon HD 6870 2GB
(2) DVI ports
(1) HDMI port
(2) Mini-Displayports
Monitors/Hardware:
Asus VH242H (Plugged in DVI)
Asus VH236H (Plugged in Mini-DP with an HDMI -> Mini-DP adapter (passive adapter to my knowledge))
I have looked into it via google and supposedly I should not need an active displayport adapter since I am using DVI and two mini-DP ports and not the DVI+HDMI+(1)mini-dp port configuration since from what I've understood the DVI and HDMI share a bridge or something? But I avoided this by using only 1 DVI port and both the mini-DP's.
When I go into CCC and try to create a desktop "group" it only lets me select 2x1 or 1x2 configuration and does not let me do 3x1 or 1x3. It detects all 3 monitors, but I am unable to use/select more than 2 at a time.
Any help would be much appreciated, as I am tres confused
Thanks!
Video Card:
(2) DVI ports
(1) HDMI port
Monitors/Hardware:
Thanks!
