lister
21
I had a P4 chip in my pc, which I built using a guide from my workplace and a prescott 3.4 ghz socket 775 chip. When I left for another job my employer asked for the chip back. I replaced it with a 3.2Ghz 641 p4. The problem is that the machine wont boot. I am getting Fail messages on the motherboard. Have I bought an incompatible chip or can anyone come up with any suggestions as to what I might be doing wrong?
evilr00t
882
It's not a prescott (90nm), it's a cedar mill (65nm). Motherboard BIOS is out of date, or the motherboard can't supply the CPU with the correct voltage.
lister
21
The message Code that I am receiving is FF and LED's 2 and 3 are lighting on the motherboard. is it possible that i must buy a new motherboard? The motherboard that I am Currently using is an epox 5lwa+.....
lister
21
I left the motherboard and some recent error messages. can you advise me on possible solutions....im at my wits end with this!!!!!! all help is welcome
1Tanker
Splendid
Apr 28, 2006
4,645
Yep, i checked on their site, and it doesn't support Cedar Mill.. :cry: It supports 5xx, 6xx, and 3.46/3.73EE. Doesn't support Pentium D, or even Celeron D. :? Bummer. GL :)
You either have to get a CPU that your motherboard supports, or get a motherboard that supports your CPU.
lister
21
thank you for the help! Im going to buy a motherboard that will run the pentium 4 641 chip. Any ideas on which motherboard would suit?
