My gaming rig of a 1 1/2 years old is making a perplexing noise.
I have a HAF X gaming case. About a month and a half ago, after cleaning the fans and the interior of the case, my rear 120mm stock case fan began making a subtle, but persistent buzzing/vibrating noise sort of. It's totally quiet at startup and stays quiet for any where from the 1st or 2nd hour, then suddenly the noise starts.
Even stranger, is that I actually replaced the fan and put in a brand new one, and the noise still persisted, so it's not an issue with the fan motor itself. I am sure that the noise coming from the rear case fan, I isolated it to that spot.
I've also tried to slightly loosen the four mounting screws, and tried different levels of tightness. No good.
Does this sound like it might just be a noise being created by a vibration occuring between the mounting bracket and the inside of the case?
Possibly something like sound-deadening pads or foam between the bracket and the case might help? Any chance that the noise could be caused by a power issue or a bad connector cable? If that was the problem wouldn't the fan just stop running altogether?
Final importnat note: Both fans I had installed in the rear NEVER stopped spinning or and NEVER stopped functioning properly. Even with the noise, they power up at startup and have run perfectly fine the entire time, even with the noise happening for four or five hours at a time.
Thanks in advance.
Thanks in advance.
