Today I put together my computer for the first time, and at after a few tries everything went great, the uefi bios started up and all the components were running. However, after that I had to do the cable management so I ended up removing my gpu at some point and when I was finally done I put it back in and it wouldn't start up. The fans weren't moving and nothing was showing up on the monitor. I tried taking out the wires and putting them back in but it didn't help.
I did what the manual said and I kept "grounding" myself by touching the metal of the case while handling the graphics card, and I kept my hands clean.
I could always just rma it if it is defective, but before going through the trouble I decided I should check if there was anything I could do before resorting to that. Thanks in advance if anyone decides to help.
