Are these parts compatible?
Last response: in Systems
April 30, 2012 5:37:57 AM
Case: Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio
CPU: Intel Core i5 2400 Quad Core Processor LGA1155 3.1GHZ Sandy Bridge 6MB
PSU: Antec HCG-620M 620W ATX12V Modular SINGLE-RAIL 48A 80PLUS Bronze 135mm Fan Active PFC Power Supply
MOBO: Gigabyte H77M-D3H mATX LGA1155 H77 DDR3 2PCI-E16 1PCI-E1 HDMI CrossFireX SATA3 USB3.0 Motherboard
Video card: ASUS Radeon HD 6770 850MHZ 1GB 4.0GBPS GDDR5 DVI HDMI VGA PCI-E Video Card
Thanks!
More about : parts compatible
April 30, 2012 5:45:26 AM
Yes everything fits
But you have a mid tower case , and a micro ATX motherboard . You could use an ATX motherboard
You are missing RAM , and a few other components
and if its a gaming build then you can do better for the same money
m
l
April 30, 2012 5:56:16 AM
Thanks for the reply! I have memory and hard drive separately. Other than replacing with ATX mobo, what other parts do you recommend to change for the same money?
m
l
April 30, 2012 6:01:30 AM
At the top of the forum is a thread about how to ask for advice .
m
l
