Solved
Help with finding a case with 6 USB ports?
Hello, I'm looking for a computer case with:
Color: Black or Black/silver or Black/grey
Type: ATX (Mid-size)
USB Ports: 6 (4 Front / 2 Back) - USB 2.0, but one or two of the USBs being 3.0 on the front would be nice too.
No LED Lights
No Fan
Cheap if possible, of course.
Thanks for any help you can give me in finding a case that fits my specifications. :)
7 answers Last reply Best Answer
More about help finding case ports
  1. hmmmm. You know you can get hubs for this sort of thing? My mobo came with 2 break out boxes - one for the card slots area, and the other for a 3.5 " bay. You could get any case and easily convert it to have support for as many USB ports as you have headers for on your motherboard.
    Thank you for the suggestion, but I already have a USB hub. However, I have more USBs than my hub can hold (they only carry up to 4 before they require a power outlet - which I don't have any more of due to so many things already plugged in).
    I suppose I could get another USB hub and plug it in if I have to, but I'd rather get a case that can sustain more of them instead.
  3. Best answer
    you have an internal or external hub?
    the most i can recall off the top of my head are on the cooler master storm series. the scout has 4 - USB2 and the stryker & enforcer have 2- USB2 & 2- USB3, as do some HAF series cases.
    USB connections on the back would depend on your mother board.
  4. Best answer selected by taylerzy.
    I have an external - I'll have to check into getting an internal USB hub, didn't know I could do that. :??: The cooler master storm series looks like exactly what I'm looking for - thank you for your help.
  6. If your motherboard has any available onboard USB sockets, you can add one of these:
    http://www.frozencpu.com/products/8888/usb-03/FrozenCPU_Quad_USB_Expansion_Slot_Port_Replicator_OR06.html?tl=g12c281
  7. here is an example of an internal hub, it goes into one of your 5.25" slots (same one used for your optical drive)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820223120
    you can also get add on cards for the back of the PC case that plug into your mobo, here is USB 3.0 card that connects to the PCI-E slot
    http://www.newegg.com/Product/Product.aspx?Item=N82E16815256004
Power Supplies Cases USB Components Product
