I'm trying to run 3 monitors in my setup.
Currently I have them setup as:
1 X BenQ 27" HDMI connected
1 x Samsung 21" DVI connected
1 x Dell 24" DVI > ActiveDisplay Port Connected with the adpater
I have read that you may only use the one side of the GFX card for Eyefinity?
My problem is: I can't get the monitor using my DVI > ActiveDisplay Port adapter to turn on (run/get a signal/etc.). I've tried switching the DVIs around between the normal DVI port and DisplayPort (with adapter) but to no success. I am only going to run the 27" with HDMI.
I am up to date with CCC drivers and the third screen is not detected in CCC nor the Windows Screen Resolution Settings.
Hope there is someone out there that can provide me with a bit of help. Cheers!
