Hey guys, I have a question for everyone regarding my recently built PC:
I put my new PC together and I had all the case fans attached to my PSU and they were all working, so I went to power on the MOBO and the display didn't work, so then I realized I forgot to plug in the 2nd power cable into the MOBO (near the CPU). Once I did this, the PC turned on fine, everything worked so I installed Windows 7, and then powered it down and plugged in the side case fan (with a little 3 prong plugin) into a molex cable I had laying up top, went to power on the PC and it wouldn't boot.
So here I was ,completely stumped, I unplugged the side case fan, switched off the PSU, turned it back on and then the PC booted up. I've had it running for 3 days now (with reboots in between) and my CPU temps are fine (23C idle, 39C load) and my GPU's are also running cool (34C idle, 65C load),
My question is this: should I plug in all the fans into the MOBO? This was my plan after work today, but it just doesn't make sense why it would not power on with that side fan plugged in, is it perhaps because I mis-managed a cable and it's looping back which is causing it not to boot?
System specs are:
HAF 932 Cooler Master Case
212 Cool master CPU fan
i5 2500k sandy bridge
GTX 570 x2 SLI
ASRock P67 Extreme4 Gen3
16GB DDR3 2133 mhz
120GB SSD
1TB HDD
System specs are:
GTX 570 x2 SLI
16GB DDR3 2133 mhz
120GB SSD
1TB HDD
