1st build, any problems with this set up?
this build is my very first and it will be primarily for video editing (hense the 16gb ram) and mild gaming...
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
HITACHI Deskstar 7K3000 HDS723020BLA642 (0f12115) 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145473
SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready 80 PLUS Certified Active PFC Compatible with Core ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9Q-16GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231429
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
cd/dvd drive
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
any advice would be great
7 answers Last reply
More about build problems
  1. all i have to say is that i hear crucial is the baddest SSD. how much are you going to pay for all of it?
  2. Get the i7-2600k for Video Editing. It will help out more than 16GB of RAM.
    yeah it's true. 16gb of ram sometimes does not make a big difference when you have a SSD from what i heard.
    1,200
    do you not like crucial?
  5. He means it is badass. :)
  6. ok
    so in regards to the performance of Adobe programs like premiere pro...
    8GB ram with an ssd basically is equivalent to 16GB with a HDD?
  7. pdgrizzles said:
    ok
    problaby yes, but if you want to waste more oney on ram you could go ahead and regret it later...
    lol, i bought a dual core 2.ghz desktop 1gb of ram, and it played 1080p videos, and made 720 on after eeffects i couldt believe.. [ no video card ]
    but still it was a litle slow,
    i suggest you buy the 16gb of ram if you can.
New Build Systems Product
