Hello, this is my first post on here so I hope too find some advice here.
So basicly a few days ago this problem started to occur. But firstly if needed here are some of my PC's specs;
CPU: AMD Athlon II X 2 250
GPU: ATI Radeon 4850 HD
Oboard GPU: nVidia GeForce 7050 PV / nVidia nForce 630a
Motherboard: Asrock Alivenf7G-GLAN DDR2
RAM: 4GIGs (Kingston I believe..)
PSU: LC Power 385W
So it all started last week when I boot up my PC and I got a black screen with the monitor LED blinking.
The Computer was up and running but wouldn't give any screen, it seemed hooking up the monitor to the
motherboard would give display.
Now sometimes over the past week everything worked normally and it would properly show something on screen
with use of my GPU. Mostly after I took the PC apart and reconnected things like GPU, PSU or RAM.
But now it happened again and reconnecting everything doesn't seem to work.
When I start up my PC the GPU's start spinning at full speed, goes down and then full up again, multiple times sometimes.
Like an engine trying to fire itself up. This is one thing I noticed. I've also tried putting the graphics card into a different computer and there it worked flawlessly, just not in mine. So it can't be a faulty GPU.
Secondly I thought it was maybe the PSU, thinking 385W combined power wasn't enough for the GPU. But then again I used it on the card for like 2 years now without any issues whatsoever.
Third, I thought maybe the motherboard is broken or so, but what's strange is that everything works normally except for my GPU to give any display.
The GPU is also no listed under the device manager.
I heard maybe taking out the CMOS battery and putting it back in a few mins later might fix it but I'm not sure, and then again it all might work again in a few hours or tomorrow, like in the past couple of days where it would sometimes work for 3 days in a row and the skip a few hours or like now a day, heh.
I'm wondering if any of you guys have any advice to this specific problem or maybe are familiar with it.
Any help is greatly appreciated!
Thanks in advance
PSU: LC Power 385W
Thanks in advance
