I need help selecting the best MOBO bang for my buck. I am planning on a new build within about the next month. I may look into being able to overclock my machine if i get the necessary parts and i want the ability to, but my uses are for DL/Streaming, tv tuner stream/capturing, Casual Gaming (but I want to be able to play most any game out), SOME Video Editing and Rendering, Heavy Word Processing /MS Office. I am looking for this rig to last me for a while since I will be poor after this while going to school, but I want to have something that will last/able to continuously upgrade. I will also be open to any comparable cheaper boards (sub $200) that would stand up until the more expensive boards like maximus v extreme come down.
I am looking to purchase:
Tower:
Thermaltake Level 10 Gt, but I may go for the Black over White and the size is the same
anyways
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133192&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-NA-_-NA
CPU:
i7 3700 (unless the K version is around 300 by then)
Motherboards:
I am looking at I dont want to go over $300 (at least form factor atx):
Dz77ga-70k
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dz77ga-70k.html/
z77pro
http://www.asrock.com/mb/Intel/Fatal1ty%20Z77%20Professional/
g1. sniper 3
http://www.gigabyte.us/products/product-page.aspx?pid=4169
z77a gd80
http://www.msi.com/product/mb/Z77A-GD80.html
golden z77h2
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=1324&CategoryID=1&MenuID=103&LanID=0
tz77xe4
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=582
Memory:
DDR3 1600
either 2 G.SKILL Ripjaws X Series 8GB 240-Pin
or
4 G.SKILL Ripjaws Series 4GB 240-Pin
I am wondering if i had 16g would it be better to have 4x4 or 2x8, but i was thinking 2x8 so
then later i can just add more 8 sticks for 32.
graphics:
it would matter by what board i got in terms of how it would affect my budget for a card, but for my purposes, would nvidia or ati be a better fit.
Power:
depends on the above, but open to suggestions.
HD:
ssd Crucial M4 CT128M4SSD2CCA 2.5" 128GB SATA III MLC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
Monitor:
LG E2442V-BN
http://www.lg.com/us/monitors/lg-E2442V-BN-led-monitor
OS:
Windows 7 but i may partition a copy of xp on it because i havent used the newer oses yet
cooling:
probably just some fans because since i won't oc out of the gate, i figure i can add something like that later on.
So, do you think I am on the right track for a good rig, or not? Any help/feedback will be appreciated and I will respond quickly.
Tower:
anyways
CPU:
Motherboards:
Dz77ga-70k
z77pro
g1. sniper 3
z77a gd80
golden z77h2
tz77xe4
Memory:
DDR3 1600
or
graphics:
Power:
HD:
Monitor:
LG E2442V-BN
OS:
cooling:
