My ~$1100 Build, Please Help
Hello all, I'm a new poster but have been absorbing the wisdom in these forums. I'm putting together a build based on that, along with the advice of an only semi-trusted friend. Primarily I will be playing Diablo III, SC2, and Skyrim, although I may want to add other games later. To the extent I'm splurging I would want it to be on the GPU and to a lesser extent the SSD (I know that the SSD is a taste thing, but load times are important to me, even though I know it might not be the most efficient use of funds). Please let me know what you think about the following build. Note that I am not going to be working or downloading music or movies, so I think the 120gb SSD should be sufficient, although I may add an HDD later on. I had chosen a Crucial m4 for the SSD, but my friend said that the Mushkin would be "way faster." He is also advising me to go with an LGA 2011 / Ivy Bridge chipset that would bump my cost up significantly, but it doesn't seem like the consensus around here is that that's necessary. I do want to overclock the CPU and GPU to the extent that's painless, no desire to SLI/Crossfire for now (but to the extent it works to have that open as a potential upgrade, that's a bonus). Prices below are from newegg, NCIX, and TigerDirect, though I'm open to Amazon, buy.com, etc.
SAMSUNG 22X DVD Burner SATA Model SH-222BB/BEBE - OEM
$15.99
Antec NEO ECO 620C 620W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
-$30.00 Instant
$99.99
$69.99
Mushkin Enhanced Essentials 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
$40.99
ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-$20.00 Instant
$154.99
$134.99
Mushkin Enhanced Chronos MKNSSDCR120GB 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
-$35.00 Instant
$149.99
$114.99
Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA1155 LGA1156 120MM
$19.99
Intel Core i5 2500K Quad Core Unlocked Processor LGA1155 3.3GHZ Sandy Bridge 6MB
$199.99
Fractal Design Define R3 Black ATX Mid Tower Silent Computer Case 2X5.25 8X3.5INT USB3.0 No PS
$109.99
A271-7850 ::Sapphire 11200-00-20G Radeon HD 7850 Video Card - 2048MB, GDDR5, PCI-Express 3.0 (x16), 1x Dual-Link DVI, 2x Mini DisplayPort, 1x HDMI, DirectX 11, Dual-Slot, Eyefinity(1.9 lbs)
$249.99
(And yes, I'll need Windows, which seems to be $99 everywhere)
3 answers Last reply
More about 1100 build help
  1. http://www.amazon.com/Corsair-Carbide-Series-Mid-Tower-Gaming/dp/B006I2H0YS/ref=sr_1_9?s=pc&ie=UTF8&qid=1335885298&sr=1-9 $79.99 & this item ships for FREE with Super Saver Shipping
    Corsair Carbide Series 300R Mid-Tower Gaming Case - CC-9011014-WW
    http://www.amazon.com/OCZ-Series-80PLUS-Performance-compatible/dp/B005A2RJOI/ref=sr_1_5?s=pc&ie=UTF8&qid=1335805455&sr=1-5 $89.99 & this item ships for FREE with Super Saver Shipping
    OCZ ZS Series 750W 80PLUS Bronze High Performance Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.910431 $374.98
    Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX806237I53570K
    http://www.asrock.com/mb/overview.asp?Model=Z77%20Extreme4 <----- another look at that board
    http://www.amazon.com/Cooler-Master-Hyper-212-RR-212E-20PK-R2/dp/B005O65JXI/ref=pd_cp_e_0 $34.95 & this item ships for FREE with Super Saver Shipping
    Cooler Master Hyper 212 EVO CPU Cooler (RR-212E-20PK-R2)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544 $44.99 FREE SHIPPING
    G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAO
    http://www.amazon.com/Sony-AD-7280S-0B-Internal-Drive-Black/dp/B0057FRTPW/ref=pd_cp_e_0 $17.99 & eligible for FREE Super Saver Shipping on orders over $25
    Sony AD-7280S-0B 24x SATA Internal DVD+/-RW Drive (Black)
    http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST1000DM003/dp/B005T3GRNW/ref=sr_1_6?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1335686168&sr=1-6 $99.99 & this item ships for FREE with Super Saver Shipping
    Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226236 $118.99 FREE SHIPPING
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102986 $249.99
    SAPPHIRE 11200-00-20G Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
    http://www.amazon.com/Windows-Premium-64bit-System-Builder/dp/B004Q0PT3I/ref=pd_cp_e_2 $99.99 & this item ships for FREE with Super Saver Shipping
    Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack
  2. Thanks. I've seen issues with the 3570k running hot. I know the price difference is negligible, so if the 3570k is really an upgrade over the 2500k I'd have no problem with it, but I'm worried about heat. Do you think that's a non-issue?
    I think it's a non issue personally - as long as you set up your air flow accordingly. That original build looks good, I'm getting that same board for my system.
New Build Systems Product
