Problems with xp detecting Digital camera
  • Windows XP
  • Cameras
  • Samsung
  • Components
Last response: in Components
August 15, 2012 4:05:44 PM
I'm having problems with XP detecting or loading the software that is pre installed in my Samsung TL210 Digital Camera. Worked fine before.How do I check and see if front usb port is working. I have 2 ports, and the one on the left side does nothing, Camera is set to connect to pc, but pc says the driver is missing. Samsung says driver is installed in camera. Can someone advise Thanks. :cry:
More about : problems detecting digital camera
August 15, 2012 7:32:07 PM
Hi :)
Try ANOTHER USB device (mouse or memory sick) in both usb ports to see if they are working properly...
All the best Brett :)
m
l
