Problem running gtx560-ti twin frozr SLI
Hey all,
A few problems
1. PC is reading master GPU correctly(gtx560-ti), but its reading the 2nd card as only "gtx 560".
2. When using the Afterbuner, it's only allowing me to change the fan speed on GPU 2. How in the heck do I switch it so I can change settings for either GPU?
3. I tried playing skyrim on ultra (worked fine), but when I switched back to afterburner to see what the GPU's were looking like, GPU fan 1 was at zero and was 15* hotter than GPU 2?
Here is my pc:
ASROCK Z68 ext4 gen3 mobo
i7-2600k clocked at 4.4
8 gbs Corsair Vengence
Thermaltake 750w PSU
Windows 7
2 MSI GTX560-ti tf2 in SLI
4 answers Last reply
More about problem running gtx560 twin frozr
  1. I read the Afterburner graphs incorrectly. CPU fan speeds match. Its the CPU usage that is defferent. GPU 1 usage is 15-20% while GPU 2 is at zero when I come back to the afterburner. Is that normal?
    It's normal when your computer is idling only one gpu works to save energy.
  3. Thanks. Any idea about question 1? Is that typical as well?
    I don't have any experience with SLI so can't say for sure.
Graphics Cards GPUs SLI Graphics
