I was building a computer, and when I tried to boot it, nothing came up on the monitor. I tried using VGA, DVI, and HDMI both on the GPU and the computer itself. It still wouldn't work. Other things seemed to be coming on, like the fans and the LEDs and a few lights on the motherboard. The motherboard I have has a thing on it that lights up and gives me an error number if something's wrong. It gave me the one for no memory installed. I double-checked to make sure I had it installed correctly and even moved it around to other slots and it still wouldn't work. I also made sure my RAM was compatible with my mobo. Another thing I did was unplug everything but the PSU and CPU and it still wouldn't work. Is the problem with my RAM or my CPU?
Stuff:
Antec EarthWatts EA-650 GREEN 650W ATX12V v2.3 SLI Ready CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
GIGABYTE GV-R787OC-2GD Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video
LIAN LI Lancool PC-K63 Black Steel ATX Mid Tower Computer Case
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
ASUS VH232H Glossy Black 23" 5ms Widescreen Full HD 1080p LCD Monitor w/Speakers & HDMI
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
SAMSUNG EcoGreen F4 HD204UI 2TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Stuff:
