Solved
Power supply For Antec1100
Last response: in Components
Power supply Master
popatim said:
hx750 has some pretty long cables.
Yes, I was looking at the cable breakout dimensions on their website. They seem to be pretty good for length. I'm not sure what he meant by too short.
Related ressources
does this SeaSonic X750 Gold 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply has long cable?
and i think this is good one lol
Amazing picture thank you for that but do you think cpu power can go behind???
i think it has enough space for that??? can you try it?
and my motherboard is sabertooth z77 it has cpupower at the top.
considering that i think it is possible how do you think about that???
Best solution
it will work ;)
Ask the community
