Solved
About my cpu power connection
Hello,
I have an asus m5a99x motherboard and was looking at psu's for my new build and I was reading in my manual that this bord has an eatx cpu connection and all the power supplies I have looked at are atx or eps , so my concern is will an 8 pin eps 12v connector work or maybe a 4+4 pin 12v connector which would be best ?
9 answers Last reply Best Answer
More about about power connection
  1. there are really both the same for what purpose you are asking about.
    yea my concern was that if I was to go with a psu that only had one, like say if it only had a 8 pin eps 12v will it be okay ?
  3. Best answer
    yes. maybe i put it wrong either the 8 pin eps or a 4+4 pin will work on an 8 pin cpu power plug. but you can't use the 8 pin eps for a 4 pin cpu power plug. (edit: without an adapter)
    that board has an 8 pin cpu power plug, you're good.
  4. loon that not quite right. most good power supply companies now use two 4 pin plugs to make the 8pin eps power plug.
    i do not understand how what you said is different than what i stated.
    :o
    lmfao
    :o
    Thanks alot for all your help, yea this is my first build and just wanted to make sure I did it correctly so I guess i'm nitpicking this thing , but its better than overlooking something lol
  8. Best answer selected by wrsj77.
    you're welcome and happy to help.
    first builds seem scary but after done and the feeling of getting it accomplished is great, then you want to put together server farms :lol:
Power Supplies Connection CPUs Components
