Motherboard problem!
  • Power Supplies
  • Fan
  • Motherboards
  • Components
Last response: in Components
August 16, 2012 9:55:07 PM
Ok so i when i try to plug in my psu connector to my motherboard it turns on all the fan for 1 second and then turns off.
I tried switching the motherboard battery and the cpu but nothing work. I also tried using a paper clip to turn on my psu and it turns on. Thanks
More about : motherboard problem
a c 723 ) Power supply
a c 1188 V Motherboard
August 16, 2012 10:01:06 PM
Is this a new build? I have had a PSU fail but still pass the paper clip test!
m
l
August 16, 2012 10:02:15 PM
Yes this is a new build
m
l
August 16, 2012 10:02:35 PM
Ok thanks!
m
l
August 16, 2012 10:17:17 PM
i try every thing but nothing works
m
l
August 16, 2012 10:18:57 PM
If everything is installed correctly, like standoffs for the motherboard all cables hooked up (24pin and 4(8)pin) and you tried with a single stick of ram it is a toss up between the board and PSU. There is a link in the guide how to do bread boarding and that would be the next step.
m
l
August 16, 2012 10:28:28 PM
is there another way because i dont have a bread board
m
l
August 16, 2012 10:38:25 PM
It is basically to assemble it outside the case and follow the steps! A case (motherboard speaker is necessary for it.
m
l
August 16, 2012 10:53:17 PM
I have tried it but i dont hear anny beeps from anything
m
l
August 16, 2012 11:06:17 PM
If there are no beeps without ram or GPU and speaker is installed then it is the most likely the motherboard but if it is still only turning on for 1sec with min components then it still can be the PSU.
m
l
