If I may, I'll run a theoretical upgrade build past you:
Quick Summary:
i7 2600k @ 4.5GHz - Already Owned
2 x 4GB DDR3 1333Mhz - Already Owned
2 x 8GB DDR3 1600MHz
Asus P8Z77-V PRO Intel Z77 (Socket 1155) DDR3 Motherboard
2 x GTX 580 in SLI
-Gainward GeForce GTX 580 1536MB - Already Owned
-EVGA GeForce GTX 580 Classified Ultra 3072MB - Already Owned
Seagate 3TB Barracuda Hard Drive - 3.5" SATA-III
2 x Western Digital Caviar Green Power 1TB 64MB Cache Hard Disk Drive - Already Owned
OCZ 120GB Agility 3 SSD
Blu-Ray Reader - Already Owned
22x DVD Writer - Already Owned
PSU, case and further cooling = ?
And the long version with links to the cheapest source I've found so far. If anyone can provide a cheaper source I'll gladly use it (I'm in UK):
i7 2600k with H100 WC
http://www.overclockers.co.uk/showproduct.php?prodid=HS-009-CS&groupid=701&catid=57&subcat=2262
This is my current cpu, don't see the need to upgrade it yet. I'm hoping to OC it to around 4.5~4.7GHz as that stays within a safer voltage range. I intend to use a H100 to keep it cool, let me know if you think that's not enough/overkill.
2 x 4GB DDR3 1333Mhz & Corsair Vengeance 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit
http://www.overclockers.co.uk/showproduct.php?prodid=MY-313-CS
I intend to build a decent albeit less powerful rig based on the old parts since they're still fully functional so I'm thinking I'll leave two of the original 4 x 4GB DDR3 1333Mhz that it has. It's also an excuse to get faster and more ram.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-513-AS&groupid=701
The first and perhaps most important thing was that this mobo enables SLI, something that my current one does not (current = Gigabyte GA-Z68AP-D3). It was the mobo upgrade need for SLI that prompted the rest of it all. That aside, reasons for this one is that it has 2 x PCIe 3.0 x16 slots (1@x16 or dual@x8) and although the i7 2600k doesn't support PCIe 3.0 it's quite possible that I'll want to upgrade soon enough. This way I'll have a mobo that is capable of sustaining the latest cpus and the new gpus can take advantage of the PCIe 3.0.
2 x GTX 580 in SLI
One is a Gainward GeForce GTX 580 1536MB GDDR5 - http://www.gainward.com/main/vgapro.php?id=452&lang=en
The other is an EVGA GeForce GTX 580 Classified Ultra 3072MB - http://eu.evga.com/products/moreinfo.asp?pn=03G-P3-1595-ER
Both of these are already owned, the links are for quick access to specs. I already owned the gainward and recently bought the evga. I know that it having the 3GB is useless when in SLI with the gainward but I got it a lot cheaper than a regular gtx580 anyway.
I've OCed the gainward in my current machine to see if I could get it to match the clock speed the evga runs at. I got it to a core clock of 900MHz and shader clock of 1800MHz at 1.075V. Since furmark throttles the clocks to half of what they should be I was using the 'Heaven DX11 Benchmark' when doing it and I've run a couple games with it like this. I've found that it doesn't seem to exceed 90degrees when running games or the Heaven benchmark but it hits 96degrees when running some boinc projects for a while. I'd imagine it would be best to keep cooler than this, especially when in SLI, any suggestions?
http://www.ebuyer.com/319640-barracuda-3tb-sata-3-5in-7200rpm-64mb-6gb-s-in-st3000dm001
Great storage for money and my current 2 x 1TB drives were getting on the full side. The currents ones are 2 x Western Digital Caviar Green Power 1TB 64MB Cache Hard Disk Drive in a RAID0 and I intend to move these over to the new build too. This is in part to save having to c&p all my stuff across, but also because I'd like to have the extra storage.
OCZ 120GB Agility 3 SSD - AGT3-25SAT3-120G
http://www.ebuyer.com/268244-ocz-120gb-agility-3-ssd-agt3-25sat3-120g-agt3-25sat3-120g
Was recommended it as being good value (£95) and it's an improvement over the 20GB SSD I have right now (which I use to accelerate my HDDs since it's too small to be of much use as storage). The Asus P8Z77-V PRO mobo has 4 x SATA 6Gb/s ports so I can connect the 3 HDDs and the SSD to them all.
I'm going to move over the Blu-Ray Reader and the 22x DVD Writer from my current system
At this point it gets to a case, PSU and cooling options and now I'm out of my depth (I've never actually built a rig before). Regarding the PSU I was suggested this site to get an idea for what I need: http://extreme.outervision.com/psucalculator.jsp
Putting in what I listed above I get the following:
System Type: 1 physical CPU
Motherboard: High End - Desktop
CPU Socket: Socket LGA 1155
CPU: Intel Core i7-2600K 3400 MHz Sandy Bridge
Overclocked: 4700 MHz, 1.34 V
CPU Utilization (TDP): 90% TDP
RAM: 4 Sticks DDR3 SDRAM
Video Card 1: NVIDIA GeForce GTX 580
Video Card 2: NVIDIA GeForce GTX 580
Video Type: SLI
PPU: AGEIA PhysX PPU
SCSI HDD 7200 rpm: 3 HDDs
Flash SSD: 1 Drive
Blu Ray Internal Drive: 1 Drive
DVD-RW/DVD+RW Drive: 1 Drive
USB: 2 Devices
Water Cooling Kit: Corsair Hydro H100
Keyboard and mouse: Yes
System Load: 90 %
Capacitor Aging (+ W %): 30 %
Minimum PSU Wattage: 1005 Watts
Recommended Wattage: 1055 Watts
This is only considering the H100 for cooling, no fans or anything else are included.
As for what I'm looking for in a case, I want something that's functional (sufficient space, inbuilt cooling, etc) but I'm really not too bothered by the looks of it. I would happily choose a cheaper plain looking one to a flashy one (provided it's just as functional).
And... cooling... I don't know what I need for that, any help would be gladly appreciated.
Basically, I'd just like to check that what I've listed above is compatible and get advice on the psu, case and cooling. Regarding a budget, I'd like to keep it fairly low but I could probably stretch to more than enough. The parts listed above that are yet to be bought come to £535.84 (this is ignoring the newly bought evga). I can make about £250 from the parts in my current pc that would be unused, if I built a new machine out of them I could probably charge expenses or something.
Many thanks for those that read this, let alone replied XD
Quick Summary:
2 x GTX 580 in SLI
2 x GTX 580 in SLI
Video Type: SLI
Flash SSD: 1 Drive
USB: 2 Devices
System Load: 90 %
