I am starting my first build and have the cheapest parts already collected. When turning on the system however, my room lights dim for less than a second. I want to know why and if this is a problem.
Here is what i have,
Case: Haf X
PSU: Seagate 750w 80+ Gold
Fans: 3 200mm Blue led Megaflows, 230mm Red led fan, 140mm fan, 7 2000 XSPC Xinruilian fans, 120mm Cougar Vortex PWM
Rad: XSPC RX480 V2
Reservoir: XSPC Single 5.25 Bay Reservoir 1 Blue LED
I have the Swiftech MCP655 pump, but not plugged in/installed.
So, the fans and reservoir LED are plugged into two cables straight into the power supply through a series of 3 pin to molex adapters. Specifically two molex cables to five 3 pin/molex adapters and reservoir led to the first PSU cable and two 4 (3 pin) fan connectors to molex, and one 4 pin to molex on the other PSU cable.
Obviously it's a lot of fans, and more 3 pin to molex adapters than what will be in my final build as my mobo has 5 fan headers.
Are the lights flickering because...
A. The Power Supply gathers all 750w at start up?
B. The amount of adapters are too many on one cable?
C. Problems with my house's wiring?
I think (hope) it's one of the first two, because the light flickers once when everything electronic on my house is on or off, just when turning the PSU on.
Any ideas?
Case: Haf X
Rad: XSPC RX480 V2
Any ideas?
