7.1 Surround Sound Card?
Can someone recommend a good 7.1 surround card that won't murder my piggy bank? Thx
1 answer Last reply
More about surround sound card
  1. please state your budget....if your budget is too tight,i think you should get a good 5.1 card instead...the best 7.1 card in my opinion is the xonar essence st or the stx...
    overall it depends on your budget...
Sound Cards Components
