How do I set up a new build with a new SSD, a new hard drive and my old hard drive.
I assume I start the system with just the SSD, load Windows 7 HP 64 bit on the SSD and then what? How do I label or specify which hard drive for the system to access first, second and then third? The SSD will be for mostly apps.
I also don't want for the old hard drive to start loading crap into the system. How do I prevent that? I do have photos on there that I would like to transfer to the new HD.
Can I eventually use the old hard drive as a back up HD or should I just use it as an external (in a external enclosure). The old HD has Windows XP on it.
I don't have much data on any of my hard drives. Thanks for all of your help and suggestions and knowledge.
The new build is this:
Intel i5 2500K
AS Rock Z68 Pro 3 Mobo
Antec B550 PS
16 gig G Skill 1600 DDR3 Ram
PNY Quadro NVS 440 video card. It's a workstation card for financial trading. I run 4 monitors.
Crucial M4 64 GB SSD
WD Caviar Black 640 GB Hard drive
My old WD 2500KS 250 GB HD
Asus 24 X DVD burner
Cooler Master HAF 912 Case
Cooler Master Hyper 212 CPU cooler
Intel i5 2500K
Antec B550 PS
