Need a good PSU for new rig
Vil
I'm buying a new gaming rig this week and need a good PSU to power this thing. Here are the specs:
Athlon X2 3800+
eVGA 7900 GT KO
MSI K9N SLI Platinum AM2
Corsair Dual channel DDR2 800mhz TWINX C4 2x1024
Seagate 250GB SATA-300
NEC DVD burner
I was looking at Ultra PSUs but read somewhere to stay away from those, I don't know much about PSUs so I have no idea which one to chose now.
Edit: I forgot to say that I might go SLI this winter.
Mr_Breeze
26
Im going with an Ultra X-Finity 600-Watt ATX Dual 80mm Fan SATA-Ready SLI Ready. Just google Ultra X-finity 600w review. The only down side to it is the efficency is a little low. Which causes more heat. That might be an issue for you since your using a AMD.
phreejak
1,376
Here are some reviews of various levels of PSU that should help inform you a little more. When purchasing somehting as sensitive as a PSU it is always best to do some research.
Midrange
http://techreport.com/reviews/2004q4/psus/index.x?pg=1
http://www.xbitlabs.com/articles/other/display/atx-psu4.html
Highend
http://www.bytesizedreviews.com/?rev_id=302
Really Highend
http://www.legionhardware.com/document.php?id=574
Here are some good PSUs that should do fine powering your rig:
SeaSonic S12-500 ATX12V 500W Power Supply ($129)
http://www.newegg.com/Product/Product.asp?Item=N82E16817151024
dual 12v rail with good amps (17, 16 amps), excellent rep, Active PFC
SILVERSTONE SST-ST50EF ATX12V 500W ($89)
http://www.newegg.com/Product/Product.asp?Item=N82E16817256001
dual 12v rails, strong amps (18 per rail), excellent rep, Active PFC
Thermaltake W0057RU-01 PurePower TWV ATX 12V 2.0 500W ($129)
http://www.newegg.com/Product/Product.asp?Item=N82E16817153031
dual 12v rail with good amps (18 amps per rail), excellent rep, Active PFC
ENERMAX Liberty ELT500AWT ATX12V 500W ($105)
http://www.newegg.com/Product/Product.asp?Item=N82E16817194003
dual 12v rail with STRONG amps (22amps per rail), excellent rep, Active PFC
XCLIO X14S4P3 500W ATX 500W ($95)
http://www.newegg.com/Product/Product.asp?Item=N82E16817189012
triple 12v rails (18, 18, 16 amps), modular, Active PFC, Good Rep
ENERMAX Noisetaker II EG495P-VE ATX12V 485W ($90)
http://www.newegg.com/Product/Product.asp?Item=N82E16817194009
dual 12v rails, strong amps (22 per rail), excellent rep, Active PFC
FSP Group (Fortron Source) AX500-A, 2.0 version, 2 SATA, PCI Express, 500W ($90)
http://www.newegg.com/Product/Product.asp?Item=N82E16817104934
dual 12v rails, amps are ok (15 amps per rail), excellent rep, Passive PFC
clue69less
Splendid
Mar 2, 2006
3,622
Athlon X2 3800+
eVGA 7900 GT KO
NEC DVD burner
Top PS makers include PC Power and Cooling, FSP, OCZ, mushkin, Sea Sonic, Tagan and Hiper. You'll find many people that use and love Antecs and it's easy to see why because of performance per $ but I got burned twice by them and just can't recommend them. Chances are, you could get a mid-range unit and be happy with it, but if it dies and takes out your pricey components, just remember that I warned you...
WRT running SLI, you can look on nvidia's site for a list of approved units, but if you run current-rich GPUs, some on the list will not handle the load. I would not build a single GPU box with less than 26A of +12V and would want around 40A or more for an SLI machine. Realize that two OC'ed 7900GTs plus an OC'ed CPU could even stress a 40A power supply, especially if your case temps are high.
