Help $900 Gaming/Audio Production
Last response: in Systems
May 4, 2012 5:33:26 AM
Approximate Purchase Date: This month
Budget Range: around 800-900
System Usage from Most to Least Important: Gaming, Audio Production
Parts Not Required: keyboard, mouse, monitor, speakers, OS, sound card
Preferred Website(s) for Parts: newegg.com
Country: USA
Overclocking: Maybe
SLI or Crossfire: No
Additional Comments: This is my first build. As stated I’m going to be using it mainly for gaming and music production. Im hoping this build last me for a few years. Below is what Im thinking about right now. Im currently sitting at $876 with the build I have below. It’s based on the $800 gaming build found here, http://gamingrig.blogspot.com/2012/05/800-gaming-pc-may... , which some changes to benefit audio production. I’m also wondering whether the ivy bridge is worth it, or the sandy bridge would be just as good. Also would the multi-threading capabilities of the i7 be worth the upgrade since I will be doing a lot of audio production.
CPU: Intel Core i5-3550 Ivy Bridge 3.3GHz (3.7GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637I53550 ($220)
MOBO: GIGABYTE GA-H77-DS3H LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard ($100)
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B ($55)
SDD: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) ($125)
HDD: Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($80)
DVD Drive: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS – OEM ($18)
PSU: Antec VP-450 450W ATX 12V v2.3 Power Supply ($38)
GPU: SAPPHIRE Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card (100314-3L ) ($170)
Case: COOLER MASTER Centurion 534 RC-534-KKN2-GP Black Aluminum & Mesh bezel / SECC Chassis ATX Mid Tower Computer Case ($70)
Thanks for the help!
May 4, 2012 7:15:42 AM
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... $339.98
ASRock Z75 Pro3 LGA 1155 Intel Z75 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.asrock.com/mb/overview.asp?Model=Z75%20Pro3 <----- another look at that board
http://www.newegg.com/Product/Product.aspx?Item=N82E168... $44.99 FREE SHIPPING
Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 997002
m
l
Anonymous
May 4, 2012 7:38:47 AM
if you are serious about audio production then you need to get a sound card thats quality is based on your budget.
and the $24 you have left really won't cut it.
m
l
May 4, 2012 3:30:29 PM
Thanks for the quick replies!
Why_Me: Im definitely going to check out that board. The features look very helpful and interesting. Have you had any experience with it?
looniam: I already have a high quality audio interface that I will be using as my sound card.
m
l
May 9, 2012 4:52:44 PM
So Im probably going to go ahead and order all the components this week, but I am still unsure about the motherboard. I was wondering if anyone could give me a little advice. I was checking out the ASRock Z75 Pro3 that Why_Me suggested, but I cant find any reviews or stats for it. The features sound pretty cool, but I was wondering if anyone had any experience with this board, or could recommend me the best one for around the same price.
Also, Ive changed the case Im getting to:
Will this case, with the manufacturer processor fan be enough cooling for the system?
Any any other suggestions, concerns, or comments are much appreciated.
Thanks!!!
m
l
May 9, 2012 8:36:55 PM
Thanks!!!
I couldn't find a review on that board either but that's no surprise seeing how there's so many new boards released in the past month and the review sites tend to start reviewing the high end boards first and work their way down from there.
m
l
